the pipe from that box down to engine block is known to corrode easily. im running mine without that pipe cos i need a new one.
Is that a good 0-60 for the 8v? i know its never going to win any prizes for its speed but that sounds about right to me?
The black box is a cover, the pipes that go into it only just literally go under the cover as there is a seperate piece under it. The piece going into it is £14.00 as i've replaced mine.
Yes it DOES effect fuel economy and while your at it might be a good idea to clean the lot out
meant to be 9.4 so its not bad for 116k on clock. + decat and induction kit. i want it superchipping to 132hp so it will be 0-60 in 8.6 seconds![]()
mines got 132 ponies completely standard...dunno bout 8.6secs though! thought it was higher than the 9's you quoted or am i getting confuzzled?![]()
