VAG-COM on windows 7??
heatfan8
Insert witty comment here
Dec 2, 2008
368
Berkshire
Will VAG-COM work on windows 7?
If so, which version do I need to download?
I have an ebay 16 pin cable and a 1.9tdi 110 leon if that makes any difference?
NI3K
58
i use 409.1, i let the cable drivers install themselves. just make sure you change the port info to com1 etc
struds
i got windows 7 running my free version of 409 fine...
i run it in XP mode... otherwise the program simply wont open!
hope this helps
Oct 31, 2006
870
Cambs
thanks mate means i can get it now knowing it won't be a waste of money!
do you know how much the full version is?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
right click icon
select properties
compatibility tab
compatibility mode - select as required (XP SP2 worked for me)
Privilege level - run this program as administrator
not sure what version i have as its on the kids laptop but i set mine as above and once i got the cable and drivers sorted and set I never had any issues
