Make sure you have the bit of plastic between the bumper & the rad at the bottom - this alone caused a few of my mk2's to overheat when I lost that.
Andy it's cooling too much at the moment because there isn't one there lol./ah i didnt read that bit..
Interesting... is it possible that too much circulation reduces cooling efficiency?
Redline Water wetter. "Cooling system heat transfer agent for use with coolant to "wet" heat transfer surfaces by 50%. This provides significantly better coolant contact in cylinder head and can reduce coolant and head temps by as much as 30degF. does not alter freezing point.
just done a bit more reading, it would appear that the redline stuff is more for older cars, modern coolant had weter incorporated...
30°F is like 1°C lol
Mork I know tbh I went faster around the ring with a passenger than a did myself but you can make time up easy at that place lol.
But if I'm gonna spend the money on the set up I want it spot on to be fair![]()
