After following the numerous threads on bulbs (side lights, dipped, main etc etc) i took the plunge and ordered myself some mTec bulbs from Hids-Direct.
Went for the MTec side light bulbs and the 55w cosmos white dipped (H7) in the end.
Anyway, they arrived in good time so i decided to drop them in yesteday, started with the side lights, all went well... job done in 5 minutes. Moved on to the dipped lights and i'd ordered the wrong bulbs !
Dont know why but i didnt specify H7 on the order so they sent H1 which on the website is the default option.
So, i now have a set of MTec H1 bulbs... i have emailed Hids-Direct to see if they will exchange them for H7's but while digging about i noticed on PowerBulbs.com that apparently the high beam bulbs are H1's.
When i was looking (or rather feeling about) yesterday i'm sure the connector for the high beam has 2 connectors in an L shape ?
anyway, has anyone replaced the high beam bulbs with anything other than standard bulbs ? If i can use the H1's in there i will and then just get another set of H7's to match everything up.
............... even if the light they emit is only as far as the end of your driveway!
