Gunnie
113
Merseyside
Might be going down to P-Torque soon getting a map and Pipercross induction kit fitted, i have just had a Jetex exhaust system fitted, im gettin a stage 1 map. What gains would i be getting??
Anything else i need to get done whilst im down there to get the best out of the map??
Before getting a map done I'd go for silicone hoses for the turbo intake pipe (tip) and intercooler to the throttle body that takes care of the extra boost plus you get a few other silicone hoses to change, a forge DV007p divertor valve to replace the standard plastic one. Think that's about it until you go stage 2 ;-)
agreed uprate the tip and dv, wouldnt bother too much on the intercooler hose just now, wont affect the map.
gains wise stage 1 will be 215bhp ish, stage 2 upto 240bhp.
have you had turbo back exhsuat fitted, if so, id be getting urated tip and going strait to stage 2
Is that the basics needed for a stage two then? Much more on top of that? Interesting to know?
yeah, turbo back exhaust, uprated dv and tip to hold the extra boost, uprated induction to provide the airflow, fine for stage 2, some maps require 4 bar fpr, fmic will help but not essential
Just pm'd Will 'p-torque' with a cost then just need to sort a date to have the work done.
Stick to the stage 1 as i will be selling towards the end of the year. Just need a bit more power for the sprinting that starts in April and have a couple of trackdays to do;)
Having read a lot on here regarding maps Will seems to have a good rep.........
