ahh. well go for it then.
i had the same thing with my headlight too. but the guy i got it from was addament it went through its last mot like it. what side is it gone on yours?
You know when you've got a Mk2 when other mk2 owners 'see you rollin, they hatin'
Or a fuel pump relay or crank position sensor...
Or the middle or a roundabout or various places on Leeds ring road...
All today, sadly![]()
You know you have a mk2 when it seems to have a mind of its own.![]()
is yours one of the early models with cruisecontrol as well i can leave it in any gear foot of all pedals and will not stall and will continue pulling at just under 20mph at 2000rpm lol
any one else have this non optional extra![]()
Nah, mine dont have that non optional extra.
1st thing with mine was that a couple of weekends ago I fitted a new thermostat housing with new thermostat and coolant sensor. Everything worked fine for 2 weeks then the temp gauge wouldnt move.
2nd thing was my hids, the drivers side hid bulb decided it didnt want to work, sidelight worked and the halogen high beam worked fine, been like that since before xmas, went out into the car tonight, put the lights on and both the hid bulbs were working.![]()
you know you got a mk2 when you got a boot full of spares
you know you have a mk2 when u recognise the mk2 you are driving to the other end of the country to buy to use as spares and its boot is full of more spares![]()
you know you have a mk2 when you go to pick up a mk2 from the other end of the country thinking its a 16v you are going to use for spares with 16v spares in the boot but it turns out to be an 8v with 8v spares and you break down half way there but havent got the right part in either car.
you havent done this have you
