The two w5w lamps at inside as you look the car have canbus system!
the two at outside w5w lamps don't! You can put every led you like! ;)
The more expensive ones I bought are going strong. If they work for another 1000 miles (3 weeks) i'll post up the make model. They are spot on so far 600miles.
Crap pic but you can see the LED's are much more substantial.
Right the LED DLR's in my xenon's are still going strong and are really decent quality. I'll post the make and model and where you can order them from tomorrow if your interested. I've done 1000 miles with them so I'd say it a pretty safe bet that they will continue to work.
The ABD LEDs broke after 3 months... And now the passenger side sidelight bulb holder is now catching in the hole. :(
Ok i changed the DRL's, sidelights and they look really good last job is the anoying orange fogs. Has anyone changed these to a more white light?
Changing Fog lamp bulbs
Hi,
I have bought a couple of ultrabright fog bulbs from Autobulbs - only trouble now is fitting them! On my Boca I think I could just squeeze my hand down to change thedrivers side bulb, but the passengers side is a 'mission impossible'.
Tried briefly to remove the nearside inner wheelarch cover but ran out of daylight.
Has anyone done this? and if so how?
I had a quick look at the weekend while i had the car jacked up and it looked to me as if you have to take the belly pan off and go from underneath.
Maybe wrong ofc :D
