Rear calipers Ibiza FR
Gooner_Mike
Teaching the kids
Jan 20, 2008
4,363
Hampshire
www.facebook.com
Alright folks, just a quicky: What are the calipers that I find on the rear of my Ibiza FR? Is there a part no.? Do any other VAG models share these calipers?
Just thinking ahead to when I upgrade to 312mm front brakes as I want to refurb fronts and rears at the same time and it would be so much easier (and I could do a better job) with them off the car!
Neo
Fool member
Mar 24, 2009
881
I`ve been thinking about this too Mike, as I have my 312 conversion ready to go on, and I have rear discs ready too. Planning to do the lot at the same time.
I know you need a wind-back tool and they take 232mm discs but so far that`s all I know.
Ad Lav
vRS...
Nov 10, 2006
4,230
Kent
Same as most VAG group cars with the 288mm fronts - they can be upgraded to 256mm vented like on TT's and Octavia vRS etc
brwmogazos
Interceptor
Apr 19, 2006
300
South Greece
I have installed rear callipers and discs etc from audi S3 as the lads already mentioned.
They cost me arround 600 euros and they are bolt on...no modifications needed except from the trimming of the mud brake disc guard to fit the bigger diameter discs!
the rear of the car seems a lot more stable under hard braking and they look alot better than those 232 cds :p
Ric 2001
Need an ID-ten-T form
From http://uk-mkivs.net/forums/p/153276/1014271.aspx#1014271
Heres all the brake sizes on the VAG range, and what they are fitted to as standard.
VW Golf R32 | Audi TT 3.2 Quattro
The Front brakes are 334mm x 32mm Vented 2-piece Discs, Twin piston(32mm/42mm) calipers
The Rear brakes are 256mm x 22mm Vented Discs, 38mm Lucas singles
Seat Leon Cupra R
The Front brakes are 323mm x 28mm Vented (grooved/drilled option) discs with 4 piston(34/38mm) Brembo calipers
The rear brakes are 256mm x 22mm Vented , with 38m Lucas single piston calipers
Audi TT-Quattro (225hp) | VW Golf anniversary | Golf GTI AUQ | Skodá Octavia VRS | VW Golf V5 170 | VW Golf V6 4 Motion
The Front brakes are 312mm x 25mm Vented Discs, 54mm ATE single piston calipers
The Rear brakes are 256mm x 22mm Vented Discs, 38mm Lucas single Piston calipers
Audi TT (180hp)
The Rear brakes are 232mm x 9mm Solid Discs,
Golf GTI 1.8T | Golf 130/150 TDI | Golf V5 150 | Seat Leon 130/150 TDI and 20VT
The Front brakes are 288mm x 25mm Vented Discs, 54mm ATE single piston calipers
Golf 2.0 8v | 1.8 | TDI 115 | TDI 110 | TDI 100 | TDI 90
The Front brakes are 280mm x 22mm Vented Discs, Single piston calipers, caliper carrier integrated into hub (FS III's)
The Rear brakes are 232mm x 9mm Solid discs
Golf 1.4 16V | Golf 1.6 16v | Golf 1.6 8v | SDI
The Front brakes are 256mm x 22mm Vented Discs, single piston calipers, carriers integrated into hub (FS III's)
