thats cool then as i am only getting rear spacers for now.
Are you buying H&R's? The cheapest I can find them is £99 online for the 15mm's !
Forge do 12mm ones but they dont say hubcentric etc. Are the Forge ones any good guys? They are about £40 cheaper than the H&R's !
Yep, £35 delivered from esp engineering 01892 613292 ;-) Happy Days!!!
I bought 10mm hubcentric spacers from esp for my LCR, great quality, but had a slight problem when fitting them to the rear. The problem comes when you try to fit them over the hub to be nice and flush. The tolerances are so small. I had to grind a little away from the back around the middle to get them flush. It only needs a very small gap on one of the sides, and it looks like your wheel is buckled !!!!!!!!
I dont know if any other people have had probs with spacers in a similar way, or if it was just me.... :blink:
Hey mate is that with bolts too??
Just the spacers, matey. I had 2 get 40mm bolts from Rare Rims, as standard bolts r 27mm + 10mm spacer I ordered 10 as i couldnt justify ordering longer locking bolts aswell at the time. To be honest nobody will tell with the bolt covers on anyway. The 10 bolts came to almost £20 delivered so bear that in mind !! ;)
