Kev Hall2
91
Bristol
I have totally stock exhaust currently on FL Cupra (single oval exit pipe). I understand that a turbo back exhaust does little for performance so was wondering if you could fit a turbo down pipe to the standard back section?
I am looking to go St2+ but if possible, would this be too restrictive?
Yes mate you can, Im running a blueflame DP. Some people run the stage 2 plus code with a standard exhaust, but the DP really is the most restrictive part and makes a nice difference.
does it make the car much louder with the dp changed?
no not at all really, its just got a bit of a deeper tone, and sounds more purposeful, like it has a bit of a growl to it. I love it personally, the std k1 dp is a bit weedy sounding.
Yep its the same
Depends if you go decat or 100/200 cell cat.
So from 200 to 500 depending on make etc
Pov if you fitted a decat downpipe like the ones on ebay for £150 that has holes for lambda sensors would this bring the management light on? also what power gains on my FR?
Any ideas. Cheers Kev
without a stage 2 map it will throw up a light.
BF decat is 200 quid, that or the piper one is what Id be going for.
