You mean that thing behind the handbrake which I assumed was an ash tray? I did, and there's what seems to be another one underneath. What do I do with it?
I thought this but was told to pump your foot on the brake pedal with handbrake on and its meant to help?!
To the OP, as you have the 1.2 engine, then you will have drum brakes in the rear, so, before messing around with the cable length, take your rear brakes to bits, clean them up and free-off the adjusters on the shoes - or replace the shoes, refit, adjust as per the Haynes repair manual (buy a Polo 9N one), and see how that now feels.
Whaaaaaaaaaat. That's sure more complicated then adjusting some cable. Thanks for the detail though. Why should I avoid altering the cable length with drum brakes?
Sounds like people had no clue, well on the Fiesta it was okay for two years, may tighten mine a bit then in that case thanks!
Adjusting handbrake cable is the last part of the puzzle .. first make sure the brakes are free and adjusted properly .. otherwise one day you will have no rear brakes due to the lack of maintainance. If you cannot be bother to look at the brakes.. pay someone or take the bus; you are risking everyone elses life too..
