how do i know when my air con is on?
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
The electronics decide when to chill the air and how much to chill it to keep the cabin at the temp you have set.
The same with the heat.
As said "ECON" will attempt to maintain the temp you have diled in without using the refrigeration compressor, This may save an MPG or 2.
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
Ill let you into a little secret, the A/C is always on to some degree, there is no coupling on the compressor, its runs constantly.
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
You need an a/c clean. Quite a few products that so it, the best ones you let off in the car and it cleans the evaporator.
jezyg
2,323
21
Derby
slightly off topic, if it stinks, what should i do?
Intially try putting it on max heat with the aircon off for a few mins often this will dry and kill the bacteria causing the smell. If this does not work then try and aircon freshner/clean.
myearwood173
I thought that these Seats has not got Air Con but has Climate Control?
HotHatchSteve
850
Climate Control is Aircon but with the ability to automatically control the temperature to a set level inside the car.
black J
so when you push the econ button,
your a/c is on??
didnt now i had a/c....?
the coldest stand is LO on the screen...
Al
7,331
9
Slightly off topic, but is it easy enough to get rid of the gas from the a/c system as I am thinking about ditching the a/c core out of the way of the intercooler.
Pheo
275
your a/c is on??
A) you do have aircon, but its all wrapped up in the Climatronic system which, as mentioned, is climate controlled e.g. will track to a specific temperature.
B) ECON Mode = Air Conditioning Compressor Off, i.e. aircon off. However as techie mentions, there is no physical decoupling of the air conditioning compressor from the engine, so presumably some component of the compressor is always spinning. Quite how it stops producing cold air, I don't know, but one presumes that it is some other component which can be controlled electronically (perhaps a pump) which is turned off so that the air con gas stops circulating.
fellowsuk
191
Sunny Wolverhampton!
I was just about to reply to that but ur answer is much better than what I was going to put. Lol.
Horace no idea on taking the air con out.
Oct 17, 2006
2,141
Mid Wales
Unless you want to lose the refrigerant I think you'll need specialist equipment. A/C service/fridge companies drain the refrigerant back into a tank if they need to work on the system. There are two valves on the A/C pipework under the bonnet - they hook into these and pump the gas out - not too sure how - on fridge vans I think they just run the fridge system and let the pump push it out - I would guess it's the same on A/C
Pheo
275
And to that point, you need to be qualified to muck about with the coolant you'd need to have someone remove it for you before you did anything!
