i dont hardly get any reception with my C2 aerial but then again i dont listen to the radio
tried having ago at removing it tonight with no luck was abit dark gave it a good pull while i was still turning it !
is there a ball or something at the bottom of the thread?
I Had The Same Problem, I Tried Pulling Mine Out And All It Did Was Carry On Turning Or Just Not Give Way At All, And For My Own Educational Purposes, Is It The Aerial Or The Actual Base Part Of The Aerial I Should Be Trying To Unscrew And Pull Off?
just the aerial. you dont want the base part to come off. if your worried about it pulling off, hold the base to the roof while you pull the aerial. the aerial will pop off eventually.
yeh as said above you dont need to keep turning it, as soon as its loose the thread is out, then its a pull and wiggle, you wont need that much force really
