the hole that you are wanting to use p34ch3y for the catch tank is covered by the washer bottle but there is about a 1" gap between the hole and bottom of the washer bottle
Have a wander round your local scrappy, I got mine from a VW/Audi breakers, not sure what model it is off now, but fits with the catch tank. Not sure if you could run boost pipe down the wing with the catch tank fitted also,
My washer bottle arrived today so got on with fitting it.
Zip ties are a temporary thing untill i get my charge pipe relocation done down the side then i will do a proper job of securing it somwhere down there...loads more room now thiough.
Im looking to rip mine out very soon but am i right in saying that after a have removed all the visable bolts the oversized washer bottle just pulls out? im not too sure about the area down by the fuel lines?
s1l3nc3r here are the pics as promised.
silicone hoses used for drivers side:
57mm 45 bends x2
57mm 90 bend
57mm straights x2
passangerside :
57mm 45 bend
57mm straight
57mm 90 bend x2
forge map tube
All i had securing mine was one bolt at the top corner infront of where the filler cap is. a rubber circle at the bottom on the corner by the headlight. and if you folow the fuel lines down you should come across a clip holding the fuel lines etc 3 in total unclip the hoses then unscrew the clip then unscrew and remove the metal retaining washer underneath then just pop the hoses off the washer pump (If your res isnt empty then fluid will come through when you pop of the hoses) a bit of a fiddle and pull and it comes out.;)
57mm 45 bends x2
57mm 90 bend
57mm straights x2
passangerside :
57mm 45 bend
57mm straight
57mm 90 bend x2
forge map tube
Thats great mate cheers. thats made it much more clear... Your cooler is the other way up to mine but its easy to work out the difference. :)
It's near enough wedged in there as it sits on the bumper lip and is held against the intercooler pipework but I also used some double sided tape against the inside of the bumper to make sure it stays put.
In hindsight velcro would have been more sensible as if I ever want to take the bumper off it's going to be a pain.
I Dont have it yet.Looking at pictures from spaare parts they have on the junkyard:)
We have a tank for the front screen and one for the front lights.But dont know witch one to take:help:
