Hi All,
My LCR (AMK) is really starting to get the best of my. I just can't seem to solve my boost problem.
The problem:
I know my car, know how it handles and how fast it used to be. This is our 6th year together. For the past couple of months i spent a lot of time and money trying to solve a very annoying boost problem.
I had a boost- and oiltemp. gauge installed when i bought the beast.
My custom chip, installed 5,5 years ago, is set to a max boost of 1.5bar (22psi) and hold this to 5500rpm. Then slowly desend to 1.0bar (15psi) till the limiter ends the fun. My boostgauge confirmed this and for years i was destroying ego after ego.
But the fun ended when i noticed that the gauge stopped reaching the 1.5bar limit. 1.1bar (16psi) was the max is it was reaching. It also felt less brutal then before. My feeling was confirmed when a mate's Golf IV GTI edition started keeping up. During this period my errorlight (tractioncontrol) jumped only once or twice. Most of the time the light stayed off but boost just didn't get to max. When i finally got a hold of VAGCOM it was showing me 2 faults:
16487 - Mass Air Flow Sensor (G70): Signal too High
P0103 - 35-10 - - - Intermittent
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-10 - - - Intermittent
After visiting my local seat dealer 3 times and spending a lot of euro's the problem wasn't solve. The MAF was replaced, the coilpack and even the spark plugs (NGK swapped for Denso). But no result. So i decided to give it a try. I ordered (was a lot faster the making one myself) a boostleaktester and started checking for leaks. The first leak i found was a huge hole in my (stock) TIP. I was very upset that the dealer didnot notice this! There was a big hole under the N75 connector. Sorry no picture of it... I replaced the TIP with the APR version. I also replaced my Hyperboost dv for the FORGE 007P (tried both the yellow and blue spring). Problem still unsolved.
Went to a different dealer in March for servicing and got a comment that my turbo was leaking oil! So a new (stock k04) turbo was ordered, but during the swap i got a call that the manifold was cracked! So both the manifold and the turbo were replaced by new stock parts. Picked up my car, went for a testdrive and....wow full boost!!.....but it lasted only for 1 day. Now the car has a new way of playing with the boostlevel. It either:
- gives me full boost for a few seconds, then gives a stutter (as if my foot is is pulled of the paddle), tc-light jumps on and then the boost drops to a superb 0.5bar (8psi). Limpmode?? Funny thing is that sometimes boost comes back to 1.1bar in a matter of seconds, sometimes after minutes and sometime it stays this limpmode. This is without stopping and restarting the car! If i stop when this happens, kill the ignition and then start again i can also start all over and the tc-light is also off again.
- gives me a max boost of 1.1bar. same as before the turbo and manifold were swapped. the tc-light jumps on bust boost stays and 1.1bar max.
So once again i checked for boostleaks with the tester. Bought a brand new compressor just to be sure. Found 1 leak and a cracked tube in this part:
Placed one major order at Forge and ordered every siliconhose availible (FM225DVRLK, FM225TH, FMKT007, FMSH159, FMTTBH, FMTTBHCS, FMTTUHOSE and the FMVT4B) for the LCR except the TIP.
Also ordered these VAG hoses and valve:
Continued ordering.....got a new MAF, replaced all coils again, replaced the N75 and installed the P-flo intake....Yep, you guessed it. Problem still not solved. From sunday till now i did a daily faultcode check with VAGCOM. I still get the same 2 errors:
Tuesday i got this 3rd one added to the list, but after a reset i didnot receive this error anymore
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 35-10 - - -
This morning i took my laptop with me to work and during my drive over here i got one error:
So this is my boost problem....
Derrick
The problem:
P0420 - 35-10 - - -
Derrick
