possible valve stem seals major (help) NOW WITH PICS OF PLUGS
daves ibiza
mate its geting to the point where i want to sell up , just cant justify it yet as ive done so much to her lol. nah serious this doing my head in just need to look inside engine;).
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
same here... now im vary as it could be my turbo now :cry::cry:....dont mind a little puff...but it smoke like a steam engine when i pull away from traffic...thats with REAL thick oil.....
20vtwy
66
Halifax
Things to check..
Compression tes. Do it correctly tho.
State of plugs.
Oil in inlet.
Oil in pipework.
Leakdownt test.
Turbo shaft play.
Does it smoke on full beans?
Does it smoke after engine braking? Like in gear down a hil not touching the pedals then accelerate.
My ibiza has a recon ko3s on and when engine braking smokes badly, when i get to the bottom of the hill and touch the gas it puffs out loads of blue smoke but not at any other time, no one seems to know why its doing it so i just stopped engine braking. Is this major?
Jan 8, 2007
2,958
Wiltshire
Dave your stalling issue may well be down to incorrect fuelling from your map which isn't set up properly for your car yet. Don't be a tart, stick with it
If it's puffing out blue smoke after engine braking that's more indicative of rings IIRC - again, compression and leak down test will help verify.
Big Daddy - do you have an oil pressure gauge to verify what it's running at? It's much more common for cars to suffer from low oil pressure than high and it won't be touching stem seals regardless. These tend to wear from excessive combustion temperatures, particularly the exhaust valves.
It's no good speculating on all these symptoms, just because 3 people have smoking and are burning oil doesn't mean it's going to be the same cause. Get testing :)
ian_cupra
yeh i am.... doing my head in and i cant afford to cough money on guess work....[:@]
did yours do it on hot and cold?
mines only does it once it comes to tempreature 80 degress an higher....:cry:
It was when it was warm, i used to stop it by just touching the throttle to take it off idle. After testing the compression etc, if time allows might be worth buying a second hand turbo (k03) and fitting it yourself (if possible) to keep cost down and see if the problem goes away.
Big_daddy
Oct 20, 2006
3,930
Brummy
exactly like me...once it goe sonto idle and trottle the gas t smoke alot...ive replaced the turbo 3 times now, 2 ko3 ands 1 ko3s...done it my self...but im fed of doing it as it not a simple job!....:(
1st ko3 (came with car)
2nd ko3
my ko3s
ian_cupra
no its not a simple job. Its was a pain for me as i had only had a k03s on it for just under a year and then it went.
ian_cupra
would cost more to rebuild than buy a second hand one for you, guys on hybrids, its cheaper to get it rebuilt i guess.
i got it down to a couple of hours to change when i was messing about with it :lol:
Just remember it might not be the turbo that is buggered though, just sounds very similar to the problem i had which is why i said it could be
Big_daddy
Oct 20, 2006
3,930
Brummy
yeh i know....i want to test the turbo with intercooler off...but it wont idle if any ic pipes off...:think:
daves ibiza
dont be tart:whistle:, ive had loads of problems now and dealt with them now its geting to point where all my money goes on car lol so its not as if its my first problem as ive coverd loads with 2 years owning my 2. anyway engine work started then ill cover work when i come to it as a spare in the shed.
ive taken pics of state of plugs and something aint right coverd in oil and top of pistons are coated in oil so something aint right , ive taken a few pic for other peoples view .
oil coated pics dont do justice
daves ibiza
When you say fueling is out because of map i was adviced this map, and had it checked and fueling is ok so not down to that , if it is the map i wont be happy and paying a visit to bill again !!!
Big_daddy
Oct 20, 2006
3,930
Brummy
today ...increased idle to 950rpm....
car now smokes on late cold....
smokes blue on idle and rev it and if i leave it in gear when drivin with no gas, then hit accelrater it blue smokes......got feeling its a turbo thign again....:cry:
bo!
170
I am having exactly same symptoms as you big_daddy.had compression test etc all ok. did you replace the valve stem seals .? Did this cure the blue smoking issue .?
