LCR DV Error Code
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
Anyone know what can cause this error code? Running Forge 007p.
Would the wrong spring cause this error code?
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-00 - -
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
This is annoying me now.
I've changed the 007p spring back to standard (green) and cleaned re-greased my DV. Still very little power sub 3k.
Had a right good look at the vac hoses and can't see any problems. The only other thing i've changed are the Turbo to DV hose and Turbo to N75 hose.
Plenty VAC from inlet mani when I put my finger over it, likewise the vac hose on top of DV.
Could this be a N249 or N75 problem?
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
Bypassed the N249 now.
DV seems to be more responsive but still very little power between 2 - 3k rpm.
Mine is the blue line (APR Map)
From my archives :D
  • Log blocks 115 and 118
  • Compare Specified vs Actual - These should be as close as possible
  • Check Block 118 (Boost Duty Cycle)
  • If it reaches 100 and the Requested vs actual at the corresponding RPM differ (a lot) then this indicates a potential boost leak/Faulty N75 Valve
I tend to put little tit-bits like this in text files that litter my HDD... really need to collate them at some point!
[edit]
Bugger - my fancy formatting had me beaten by DJP :p
[/edit]
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
Code:
Group A:	'115				Group B:	'003
	RPM	Load	Absolute Pres.	Absolute Pres.		RPM	Mass Flow	Load	Ign. Timing
TIME					TIME
STAMP	 /min	%	 mbar	 mbar	STAMP	 /min	 g/s	%	 °BTDC
346.98	2160	12.8	970	990	347.38	2200	15.22	11	11.3
347.78	2200	72.2	1120	1000	348.19	2240	35.19	19.6	29.3
348.67	2320	78.2	1160	1140	349.09	2360	36.56	18	30.8
349.49	2400	85	1350	1200	349.89	2480	43.72	21.2	29.3
350.3	2520	70.7	970	1270	350.8	2520	3.28	3.9	38.3
351.2	2520	15.8	970	1040	351.6	2520	7.14	4.7	3.8
352.11	2480	13.5	970	1000	352.51	2520	35.03	20	26.3
352.9	2560	94	1950	1090	353.31	2640	64.61	100	24.8
353.71	2760	130.8	1950	1470	354.11	2840	96.64	100	10.5
354.53	2960	187.2	2260	2100	355.02	3160	131.39	100	4.5
355.42	3320	191.7	2330	2380	355.82	3480	147.89	100	6.8
356.24	3640	191.7	2340	2370	356.64	3800	150.36	100	9.8
357.14	4000	191.7	2310	2330	357.54	4160	164.5	100	12
357.94	4320	191.7	2280	2290	358.35	4440	167.81	100	13.5
358.75	4600	191.7	2270	2250	359.15	4720	175.42	100	11.3
359.57	4880	188	2290	2210	360.05	5000	185.47	100	12
360.46	5160	191.7	2240	2220	360.86	5280	194.67	100	8.3
361.26	5360	191	2190	2170	361.66	5480	198.08	100	9
362.06	5600	191.7	2110	2060	362.46	5680	199.72	100	6.8
362.86	5760	175.9	2040	2110	363.28	5880	201.03	100	12
363.68	5960	185.7	2010	1980	364.08	6040	206.58	100	12
364.48	6120	172.9	1970	2080	364.89	6200	205.92	98.8	9.8
365.28	6240	182	1960	1990	365.69	6320	204.61	98.4	12.8
366.09	6400	176.7	980	1970	366.49	5880	2.61	6.7	7.5
Code:
Group A:	'031				Group B:	'020
	Lambda Factor	Lambda Factor	Bin. Bits	Bin. Bits		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
TIME					TIME
STAMP					STAMP	 CF	 CF	 CF	 CF
200.73	0.938	0.945	        	        	201.23	0	0	0	0
201.73	0.984	0.945	        	        	202.14	0	0	0	0
202.54	1.07	0.945	        	        	203.04	0	0	0	0
203.44	1.008	0.945	        	        	203.84	0	0	0	0
204.25	0.93	0.945	        	        	204.65	0	0	0	0
205.05	0.867	0.945	        	        	205.47	0	3	0	0
205.97	0.969	0.945	        	        	206.37	0	0.8	0	0.8
206.77	1	0.945	        	        	207.17	0	3	0	0
207.57	0.75	0.945	        	        	207.97	0	5.3	0	0
208.37	0.992	0.945	        	        	208.78	0	5.3	0	0
209.28	0.969	0.945	        	        	209.69	0	5.3	0	0
210.08	0.977	0.945	        	        	210.49	0	5.3	0	0
210.89	0.844	0.953	        	        	211.29	0	4.5	0	0
211.69	0.992	0.945	        	        	212.11	0	0	0	0
212.6	0.984	0.945	        	        	213.01	0	0	0	0
213.52	0.93	0.945	        	        	213.9	0	0	0	0
214.32	0.953	0.945	        	        	214.81	0	0	0	0
215.21	0.953	0.945	        	        	215.61	0	0	0	0
216.03	0.953	0.945	        	        	216.41	0	0	0	0
216.81	0.938	0.945	        	        	217.23	0	0	0	0
217.63	0.953	0.945	        	        	218.03	0	0	0	0
218.44	0.953	0.945	        	        	218.84	0	4.5	0	0
219.23	0.961	0.945	        	        	219.64	0	3.8	0	0
220.14	0.953	0.945	        	        	220.56	0	0	0	0
221.05	0.961	0.945	        	        	221.45	0	0	0	0
221.95	0.93	0.953	        	        	222.36	0	3	0	0
222.75	0.844	0.961	        	        	223.16	0	0	0	0
223.56	0.86	0.945	        	        	223.98	0	0	0	0
224.46	0.906	0.945	        	        	224.87	0	0	0	0
225.27	0.969	0.945	        	        	225.77	0	3	0	3
226.19	0.828	0.945	        	        	226.68	0	3	0	3
227.08	0.977	0.945	        	        	227.5	0	3	0	3
227.98	0.867	0.953	        	        	228.39	0	3	0	3
228.91	0.938	0.961	        	        	229.31	0	2.3	0	2.3
229.71	0.977	0.953	        	        	230.11	0	0	0	0
230.51	0.953	0.969	        	        	230.91	0	2.3	0	2.3
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
This is the bit I don't understand....
Code:
Why is requested boost so low @ 2520rpm
