Big-Pete
Always on the Limit
Aug 8, 2010
2,969
ok anyone know what relay it is that turns the mains off when i go full beam!? its doing my swede in having 1 or tother!!!!
on mine main beam stays on when you flash and/or hit main beam
is it Gti twin lamps on yours - if so are they original or changed to ?
I can't remember the exact one but try holding your hand on across the box and work the lights - soon narrow
Post up a close up of your headlight, we'll tell you if its got the right ones.
GTi Lights look like this:
Standard ones like this
oi cheecky ****ers i got H1s in mine but it did have H4s in before i changed em over! (ignore the odd indicter)
please note car on right is mine
sorry pete, looking through you build thread, it looks like you got standard headlights on but you can quite clearly see in the other pics you got gti lights.
i did change em from the gash tastic H4s to GTis BUT i got 16vs and its a cupra sport GTI on the log book!?:shrug:
no i meant that i have a gti cupra sport 16v and it should come with with H1s but i had H4s, ive changed em over!
any help with the high beam main beam problem!?!?
H4's normally operate either high or low not both so maybe the car is wired that way as it was H4's originally - wierd though
if you can find the relay (reach under drivers side dash behind the glovebox probably be clicking when you flash) let me know the part number and i'll compare it with the one on mine if it helps
maybe as simple as a relay swap
were the light's plug 'n' play btw ?
yeah mate there plug and play! the joy of vag! it was a piece of cake!! ;) will get parts number when its light outside!
