I took mine off so I could hear the engine, it had also started to go mouldy and rub on one of the pipes. Bit of subject, but has anyone else noticed that the underneath the bonnett isn't fully painted? Or is it just mine?
On a recent service one of the coilpacks needed replacing due to rust!
(A second coilpack was rescued with a bit of cleaning)
You can guess where the water was coming from that caused the rust on the coilpack.
It was the clips that hold on the plastic part on the high end of the bonnet.
Water was getting through, sitting on top of the engine and also in where the coilpacks sit.
If you do have the sound deadening removed it might be worth a check after rain and cleaning to see if you have any water hanging around the coilpack area
The worst possible thing to have above the top of the engine is a permanently soggy blanket of mouldy soundproofing in my view...- just bin it and then use an engine cover to protect coilpacks ?
