Don't forget the OEM tip collapse's On OEM boost especailly once warm....Now your in the 20psi area...
Have you tested what Psi/bar you are getting when on wot from the fuel pump? You can easly install a guage that will tell you..
When i had my old Nova Turbo mapped and the same with the Bt Ibiza they did this..
Good idea, gonna have to look into this as well. What fuel pressure should we be seeing, is it 3bar?
Might also be worth testing the battery voltage, read somewhere that the pump will show less flow if it's not getting enough power.
