Carbon Canister Removal - Tank Ventilation??
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
yea this is what i was thinking
i wonder if it would be safe ie the oil vapour fumes and the petrol mixed together :shrug:
yeh just thinkin..:think: if oil fume started goin down the petrol vapour line... wont that cause sluge and blockage...:think:
Jan 8, 2007
2,958
Wiltshire
I just run an extended vac line down into the front arch behind the bumper and never notice any smell in the cabin, and I've left the N80 sensor plugged in but extended the wiring to hide it in the scuttle tray.
If you unplug it you'll get an EML
Reactions: Andrewwright
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
dose it make a loud clicking noise
Nov 2, 2004
9,335
South Wales
Even plugged in after idling for a while it will throw a EML.
Ive tried a 33ohm 50 resistor, plugged in, raising idle RPM and it always comes on after reaching running temperature then idling.
Ill try and work it out soon with the electronics boys in work.
cupraR59
153
grimsby
would a spare n249 solonoid work will trick ecu in to thinking it plugged in without the buzzing ??? let us no if it works
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
if you could phil that would be a grate help and much appreciated
jaypee
174
i removed the box kept the unit attached and cabled tied it, put a pipe right down as far as i could down the arch. Come to mention it, I always wondered where that petrol smell in the car came from :lol: I've got some resistors to try instead of the clicking unit, will test over the weekend and post up any findings.
jaypee
174
the 330r i had didnt work, im gonna try a different set this weekend, i have a few others im gonna give a whirl... hopefully have an update tommoro
jaypee
174
would you believe that my car isn't throwing up any faults with it unplugged and no resistor? hmmm
May 25, 2008
2,400
cambs
Yeah quite possibly
All cars seem to be different some bring on the light but some dont
Right then I'm just going to remove it and see what happens , I could connect an ohmmeter to it to see what resistance it is when it's venting
Nov 2, 2004
9,335
South Wales
Someone needs to get to the bottom of this now to find out what resistor is needed. If you could do that Tom that would be great.
My light seems to come on after driving it then stopping and idling, like waiting in traffic.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Exactly where I used to get it. I still think it's related to a lamda condition that the ecu expects to see after venting.
chris_200120vt
MR carbon fibre
Oct 4, 2008
2,711
YEADON, LEEDS
16824 P0440 EVAP Emission Contr.Sys. Malfunction
16825 P0441 EVAP Emission Contr.Sys.Incorrect Purge Flow
16826 P0442 EVAP Emission Contr.Sys.(Small Leak) Leak Detected
16827 P0443 EVAP Emiss. Contr. Sys. Purge Valve Circ Electrical Fault in Circuit
16836 P0452 EVAP Emission Contr.Sys.Press.Sensor Low Input
16837 P0453 EVAP Emission Contr.Sys.Press.Sensor High Input
16839 P0455 EVAP Emission Contr.Sys.(Gross Leak) Leak Detected
