Ordered a ko4-001 hybrid which is practically a ko3s I'm told
I've got a forge tip to go on it but I'm not sure I'm missing anything to make it fit?
Do I need one of these
http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=190101&product=FMIBTH251
But the one For a ko3s turbo?
Need info as fast as possible.. Hoping to do it all on Saturday...
Thank you :)
If you have a Forge TIP on your K03 it will fit the hybrid. The hybrid is basically a K03 or K03S housing with K04 internals so looks and fits the same as a K03. You don't need any reducers or anything like that to use the TIP. :) It should be 45mm at the smaller end of the TIP.
Hope that helps.
Joe
Sounds as if your hybrid has used the compressor housing/ inlet from the K04. RobbieC has a diagram on his build thread, around page 10 IIRC. Look for "custom tip" with a diagram of his K03S Hybrid.
Joe
Thanks Joe I'll take a look :)
And I could use the reducer yes seems like the best option ATM! Gunna ring forge see what they can do for me!
Got it from universal turbos :)
Post #256
http://www.seatcupra.net/forums/showthread.php?t=217772&highlight=k03s+hybrid+build&page=13
Effectively you could use the reducer that RobbieC used, turn it around and get a 45mm coupler (you would have to trim the Forge TIP though) that could be a poss. Otherwise you could make a custom TIP like I have done but it till cost about the same as the Forge one - I did it because it meant i could hide a lot of the ports and take off's. RobbieC did it in order to try and create more air flow although he claims the gains weren't worth the effort.
Here's a pic of mine:
