Davec600
Hi guys.
I have a mk2 Leon with the aero body kit and in this big freeze we've been having, all the snow being thrown up from the front wheels got in under the side skirts and popped one of the removable jacking point parts out. Not sure what you'd call it but does anyone know if these can be bought separately from seat?
It looks terrible as theres a chunk missing from the skirt!
Any help would be much appreciated. Thanks in advance.
Dave.
Your local Seat dealer can supply you with a replacement jacking point cover ask for a quote for part...bair in mind that it will need to be sprayed to colour match witch is extra ..mine cost me £30 all in...but that was 2yrs ago...there not a very secure fitting...I fixed mine with a small 'blob' of clear silicon..easy to remove if needed to use the j/point
LoL yeah im missing one to! Mine was stolen however, but it's 18.50 for the part, that comes in a grey primer colour i think! Then it needs to be painted, but to mix up such a small batch, they still charge for as if it was the full skirt......so for me they quote 45 quid for painting and glossing! so i was like cba it might get stolen again! :(
Hi guys.
Dave.
David at Sere Motors sells them for around £15 a pair i think. He is a forum member and can be contacted HERE.
I was successful in having my missing jacking point cover replaced under warranty :)
Seat says as long as the area isn't damaged, they would cover it. Not sure if you'd get away with it with the snow thou??
Comes sided front and rear in kit,I have lost a couple in the snow and possibly nicked.To hold it on now i drilled a small hole in the bottom of it and through the skirt and cable tied it together secure now.As for painting mine is Candy white I sprayed it myself with an aerosol doddle. As mentioned give Sere a shout
