mrle88
outside temperature display is not working and not showing any signs. I figured that the outside temperature sensor, but that he showed to be defective-40c. What are the possible faults?
yeah the sensor is on the n/s wing mirror and they are pritty temprimentle and always brake carnt do much once they read lines but -40 mine did that the other day and was fine a few days later but just make sure there is nothing on the sensor might help mate not 100% tho
are you sure if you replace the sensor that will work. No backlight and there is nothing in the display. The display is situated between the RPM and KM / H
What? What car have you got? The temp display should be in the top left of the massive screen / headunit thing in the middle of the car.
Mine is the same i have just blank lines on my temp display are they cheap to replace the sensors and are they easy to replace yourself?
