Outside temperature display Seat Ibiza 1.4
mrle88
outside temperature display is not working and not showing any signs. I figured that the outside temperature sensor, but that he showed to be defective-40c. What are the possible faults?
B12rky
61
Redcar Cleveland
yeah the sensor is on the n/s wing mirror and they are pritty temprimentle and always brake carnt do much once they read lines but -40 mine did that the other day and was fine a few days later but just make sure there is nothing on the sensor might help mate not 100% tho
mrle88
are you sure if you replace the sensor that will work. No backlight and there is nothing in the display. The display is situated between the RPM and KM / H
ndbrgr
THFC
Jul 21, 2008
1,023
Kent
What? What car have you got? The temp display should be in the top left of the massive screen / headunit thing in the middle of the car.
shaneyibizamk3
Mine is the same i have just blank lines on my temp display are they cheap to replace the sensors and are they easy to replace yourself?
