The ultimate dyno thread
vRSy
Fabia vRS
Jan 8, 2009
1,470
London
Post your dyno graph and mods for your Ibiza/polo/fabia or similar engined motor
For this thread to stay on topic please refrain from submitting useless posts about dyno lottery etc.
If you want to start a discussion please copy the dyno graph and paste it into a new thread with your discussion and or question.
Please use the following template to make sure all the information gets entered in one post.
Car/engine: Skoda Octavia vRS 2.0 TFSI
Tuner/stage/settings Revo stage 3 Settings:b-9 f-8 t-7
Engine Modifications K04 turbo conversion, evoms intake, miltek TBE, S3 intercooler, S3 injectors, autotech HPFP
Type of Dyno/operator Dyno dynamics/Jkm perfomance
miscellaneous details ambient temp 20 degrees, car suffered wheel spin etc.
blue line =stock, Redline =stage 3
summary
Fuel economy improved, hesitation etc etc
vRSy
Fabia vRS
Jan 8, 2009
1,470
London
Car/engine: ibiza cupra 1.4TSI
Tuner/stage settings: Stock map etc
Engine Modifications: ITG maxogen intake
Type of dyno: Dynojet
Misc details: not mine, copied frm another thread:funk: Red line =stock, blue line =stock + ITG intake
WJs
MeepMeep
Oct 26, 2006
497
Netherlands
Car/engine: First one FR, second one a Cupra. (both 1.4TSI)
Tuner/stage/settings: JD Engineering standard chip.
Type of Dyno/operator: Superflow 4wd Rollenbank
GrDuDe_Cupra
234
Car/engine: Ibiza Cupra 1.4TSI (turbo-compressor)
Tuner/stage/settings: XXexelixis(Greek), Stage 3, 1,6bar & 1,3@limiter, 13 degrees of advance
Engine Modifications: Hybrid K04 turbo conversion, BMC intake, Custom Exhaust decat, universal intercooler, Forge 007 BoV.
Type of Dyno/operator: MAHA/XXexelixis
viktor
upsolute stage1+
Nov 2, 2009
236
barcelona/vigo (spain)
Hi mates, here are my RR figures.
Car/engine: TSI twincharged 180hp
Tuner/stage/settings Upsolute
Engine Modifications: Apexi direct intake (without heat shield)
Type of Dyno/operator: maha fps 2700
Miscellaneous details: ISO measurements, recently calibrated maha dyno, upsolute software, 98 oct RON.
We had a little problem with intake temps, at next weeks we launch again with a intake heat shield.
standard:
remaped:
Please comment, thank you.
jc_boc
Missing the CUPRA R!
Jul 18, 2008
9,303
7
Desborough
Not bad at all mate. What remap is that? Not too much of an increase in torque but a good increase in power.
vRSy
Fabia vRS
Jan 8, 2009
1,470
London
no increase in power until after 4k though. Not a bad thing i guess, it just means day to day there will be no change in the car.
reference the torque increase if think its the scale which makes it look like not much of an increase. each small square is 20Nm so its around 15NM minimum increase from 2900-4250rpm. but closer 30/40Nm above and below that. It'll save the clutch and it'll still be enough to notice on the road. its a clever reserved map that.
viktor
upsolute stage1+
Nov 2, 2009
236
Thank you mates for the replies, are very useful, the remap is upsolute.
I agree with your opinions, it's a conservative map for the day a day, I was very gutted with the engine problems reported by other mates and I want a conservative map (for the moment). The dyno was recently calibrated and the figures reached by the car are quite accurate. It's curious to see how the car reaches the manufacturer figures at first dyno run.
Comparing the graph with other chiptuners (revo, apr..) , what do you think? ...
Thank you.
Apr 23, 2010
914
Here
Might as well add mine.
Car/engine: ibiza 2.0TDi FR
Engine Modifications: None
Type of dyno: Whichever one AMD Essex use :)
And slightly weird remap graph, not sure if it was wheel spin or a map fault. Happened on all three runs though so doubting wheel spin, it's due to be looked at soon so we'll see what happens.
Car/engine: Still the same Ibiza 2.0TDi FR
Tuner/stage settings: Stage 1 map
Type of dyno: Whichever one Jabbasport use :)
