Not sure if illegal, should be though
As the bolts were not designed to take lateral forces when the centrebore is too big, so i'd hate to imagine the consequences!
You can get "spigot rings" that fit inside of a bigger centrebore, to make it correct, cost maximum of £20 and worth every penny!
so will Vauxhall wheels go on a seat ibiza 4 stud
I'd imagine if the tester were to notice this then it would be considered Dangerous, thus failing the MOT. If the bolts snap (which happens easily with the pressures you're talking about) then it's bye bye wheels, probably the car and possibly you if you're at speed. Is it really worth it lol
Spigot rings FTW mate.
Also here's a little list.
Honda (Hub size is tight, snug is an understatement)
Renault (Bore Size is 61/62 mm so spigots required)
Rover / MG
Vauxhall
and anything else that's 4x100 really. FIAT / Alfa ones are 4x98 and fit with wobble bolts.
I know it's nigh on impossible to check, and I'm probably being overly paranoid, but is it illegal/MOT fail if the hub center of the wheel is bigger than the actual hub centre?
