What to use when polishing the manifold?
Nov 7, 2009
858
Hi. As sed above. I want to polish my manifold and not sure what to use in the stages as i want a good finish. Cheers
Nov 7, 2009
858
I had an idea about using different grades of wet n dry. What grade to start from and finish of on? And at what stage would i have to change the grade wen rubbing down?
chris_200120vt
MR carbon fibre
Oct 4, 2008
2,711
YEADON, LEEDS
what mine looked like needs re polishing though but got something new up my sleeve now;)
Nov 7, 2009
858
Im gonna paint the rocker cover danny....so shut it! Lol not gonna polish all the mani. Jus the square bit at the top. Gonna paint the tubes black
D.K
LCR 225
Oct 24, 2007
6,309
se london
What did you use to polish it up?, mine has a few small scratches that I need to polish out and she,s looking a bit dull also.
Normally Autosol and a soft clean cloth, just rub it really hard till the paste goes black and waxy, then buff it off
D.K
LCR 225
Oct 24, 2007
6,309
se london
Yeah, I use the autogylm stuff, just wondering how to tackle the scratches.
If there deep you'll have to wet & dry them, I'd start with a 1000 grit and see if it takes them out, if not then try 800 and work up to the finest you can get hold of, keep the surface wet and mix a bit of washing up liquide in with the water, it will help prevent the paper from cloging.
