![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
No still not sorted it pal, I have had a new knock sensor, I have had the wiring checked, I thought it was a bad re-map which was on the car before I bought it, so I had a new re-map yesterday but the fault is still showing. Don't know what to do now.
, I have stripped the engine down this morning and found what looks like a little air leak on some breathers near the knock sensors, but can't see that bringing up a fault on the knock sensor!!, but fingers crossed,
They bolt to the front of the cylinder block, Knock sensor 1 does cylinder 1 & 2, Knock sensor 2 does cylinder 3 & 4.
Gav
There on the front of the block , one one left one on right, 13mm bolt hold em onto the block!Where are these knock sensors? I recently had a code come up on vagcom for 'knock sensor 2' intermittent or some sort.
Sounds along the same lines. Cleared the code, but car isn't going into limp mode.
Yeah the car is in limp mode, I clear the fault, it goes like shite of a shovel, then about 2 mins later the fault is back on and back in limp mode,, I have stripped the engine down this morning and found what looks like a little air leak on some breathers near the knock sensors, but can't see that bringing up a fault on the knock sensor!!, but fingers crossed,
Gav
Hi mate, i changed coil packs today and all was wellHi lee, No still not sorted it pal, I'm gonna try the coil packs today and if that doesn't work then, I got no idea![]()
