Maybe you should do the taster session I'm doing on the 19th April (tuesday evening) going on track at 1940 for a 20 minute blast, cost? £20 Bargain!
Its been very slow! Thankfully it's going into bodyshop 3 weeks today, got some other goodies to fit too
Can't wait to get it back once all repaired and bit and pieces fitted, will have a huge smile!
Seeing pics of your car always makes me want to continue and make a pure beast!![]()
t0m how you getting on with those 3 fault codes have you managed to take off the front bumper yet and check the intercooler pipes for any boost leaks and clear codes
I need you to keep an eye on the pressure drop fault code you have 17705 check dv
i need to know really if its map related or something else, if yours goes and doesn't return let me know i clear it but it comes back
yeah would like to do a track day in mine don't think its ready stopping power wise at the moment BRAKES!
would love to do castle combe, nurberg ring that would be amazing!
thanks t0m do you think you can scan your car again for me when you get a chance and double check that pressure drop code again one final time then i will know then thats the only code im getting
think its the badger5 tip although have checked and rechecked it or maybe my maf, or the dv was opened at AMD for yellow spring 99% no splits on any of the pipes
were no boost leaks before went into AMD now not so sure only things that have changed are mentioned above
thanks for sorting those pics out![]()
Mint! Great job!
I love that the red hosing gives a hint as to what's lurking ready to go.
Great example of a LCR
Looking awesome as always mate. Top job. May have to purchase myself some spacers!
Cheers mate!
Spacers rock, do it. Sets off the car so well especially if lowered.![]()
