hello..
i have got seat altea 1,9tdi sport reference 2006..
i wonder if you can
help me, i have got the
problem with the engine.. i ve been trying to have it fixed, i put the car into the garages few times already but the
problem hasn't stopped.. the
problem is that, if i drive and im changing the gear in the low torgues from low speed to higher, (3-4, 4-5) i feel vibration ( shaking ) of the engine and in the car as a whole.. The vibration appers mainly in the low tourgue, during the acceleration but in the higher torgue ( 2000ish ) when I change the gear to higher i dont feel anything at all... this car was bought a year ago with the 55000 milage then. I havent noticed this
problem after I bought it, because this car used to be used only for short distances only. i ve noticed that after driving longer distance myself ( 2 hours ).. I drived this car twice to my country , which was about a 1000miles each way.
this
problem occurs once the engine has been warmed up ( let say 15min after starting the cold engine)..
i had the engine tuned by the profesional company ( flushremapping) a couple months ago a the
problem still exists. The new clutch flywheel has been replaced in an order to get rid of the
problem and also there is a new cambelt.. After asking about this
problem, each garage keep saying that there is a different
problem and Im fed up..I ve been loooking for the answer on the different forums online and i found one good one ( tdiclub.com) where I found out that there may be a
problem with : cvjoints, enginemount, injection, flywheel...so therefore I had the clutch changed , i cleaned the injections with the fuel cleaner too.
I spent already over £1000 trying to fix it but as you can see,it didnt work. So since then Iam being careful where which garage im going to put my car next time in. It is a really good car and I just want to have it fixed. can somebody
help me?? i live in watford(herts)
