So what use do i have for a silicon 90degree bend if im to fit straight pipe to catch can? i was told when ordering i needed one?
you can get rid of the y piece and use a straight bit of hose, thats what i did, and fitted the two small valves into the new hose,
Yea block the nipple under the Inlet manni and block off the brake booster AFTER the one way valve job done
Thats what i did they were attached to same section anyway so binned that with y-piece and got around a metre of silicon hose and cut a few sections to fit the valves between
