Yep i get looooooads of smoke
yer i did see a video of urs on another forum
as far as i no black smoke is unburnt derv but u get this as u want the power so it over fuels the engine to give you maximum torq
im not seeing this at all runs as clean as it did with the dpf
only problem i hav now is its smoking like my old 306 hdi did only smokes on idel and it dont look to be black smoke so its kinda worrying
yer seemed to be wen its cold ill go out l8a and get it warm and check if its still doing it only tryed from cold atm as i only just noticed it
Mine doesbt smoke on idle but will if you rev it
Sent from my Darky Rom Powered Samsung Galaxy S using TapaTalk
ill hav to get dyno results and work from ther
if ther low its either not been maped or thers a problem with the engine
btw just tested it and wen engine was hot no smoke on idel :D thank god
shame none of u live neer me as we could compare cars and how they feel
as i dident feel the car is all it could be decided to get it on the dyno
here is my dyno result :(
not impressed at all considering its supposed to be a stage 2 with dpf delete and all exhaust restrictions removed
as far as i kno u can get 200 from a standard 170pd
gave jbs a call they asked me to take the car back for it looking at wen im in the area said it was posibly a bad dyno result
the guy at scooby clinic said in both runs it made the same power
for some resson i feel i was given the stage 1 custom code ?
file.php
Mine made
235.5bhp and 340 lb.ft on JBS Rollers
201 and 360lb.ft on AwesomeGTI Rollers (found out my Downpipe was leaking badly after)
Let us know what they say mate when it goes back to their's ;)
thx ill keep u updated
think ill call them tomorow and see if its ok for me to go down to jbs
i kinda feel in the wrong and like im messing people around and yes difrent rollers produce difrent results but the power does seem down on ther quoted power and also on the majorty of the peopel on these forums
he did say that 220 is what is expected from the 170pd with dpf delete and standard exhaust as soon as i mentioned it had no back box and only made 200 the conversation changed and thats when i was told to drop in for a check
i just dont wana come across as a **** but i also would liek what i payed for :)
do i hav to specialy ask for the wild stage 2 cc map or is that what should be on now ?
says phase 2 software on the recipt
btw thx again and
p.s if ur down pipe was leaking how come this caused a 30bhp loss ? i thort that back presure wasent needed at all so in thory with it leaking should of reduced even more back preshure (but then again probably disrupted the airflow)
its not been on rollers since Milltek Replaced but it feels alot better since they did , It just seems a little flat im not sure if it was just in my head
a ok np if you ever plan a go at awsome again let me kno and we could meet up and see how we compare on the same day could be an idea to get all the stage 2 cc people togetha would be intresting
kilner dont let them try and fob you off, make sure they have a good look at your map, dont let them put it straight on their rollers cos it will miraculously start producing 240bhp and they will say there is nothing wrong.
As a side note, Awesome GTI are having an open day / bash on July 31st, its in their section, if you fancy going just let them know.
well went down to jbs today i w8ed in the reception for around 45mins as they had the car and had a test drive and said everything was ok said the exhaust readings looked a bit high or somthing
so i booked it in for a dyno run next thursday and he said lets get it on the rollers first and then he will sugest options with the exhaust i got a quote for a milltek r32 style for my car and it was 600 .... he said its exspensive and gave the impretion he wouldent botheRt 240
he did look at my dyno graph and said somthing like 320 torque from 200bhp isent possible and that 320 torque is around the 220bhp mark that they quote me so i hav no idea how people can get 240bhp
btw they checked the car over free of charge as i went to my car they had left the vag-com wire in i had a little think and returned it ;)
and yes graham id be up for that sounds good wonder if we could get a few of the other stage 2 pd170 people along
With a better exhaust it would be possible ish. I had the mild map on with standard exhaust and made 223bhp and 342lb/ft. Now have the wild map and full milltek and it is quicker still. I reckon it's around 230-235 based on before figures and how it drove compared to now.
Although it still doesn't feel 230bhp some times, can get caught out sometimes and have to really hammer it to keep up with other 200bhp cars.
Mine is around the same as a impreza sti (270 ish bhp) if I can get the power down. If anything it is a bit quicker on the top end side
I agree sometimes it can feel like its putting out 200 and then sometimes it feels like 240!
do you hav to ask for this wild map or somthing or is the phase 2 map the wild map i even asked if i had an uprated clutch would u put a difrent map on and he said no it would be the same one as im on now
i fail to see how they can call it custome code should be more like generic code
btw this is a pic off my back box so i doubt this is my restriction in the exhaust the only part the could mayb still be restricting the exhaust is the middle section witch is still the original exhaust but as far as i kno having a stainless of the same size wouldent make any difrence other than it wouldent rust :)
here it is
[IMG
Uploaded with ImageShack.us][/IMG]
please feel free to comment im not that happy with the soud of my exhaust atm but its a work in progress and dont rly want to spend 600 for a milltek cat back
lol what is the point of a dpf delete if you struggle to keep up with 200bhp cars sometimes? id want the power all the time not just when it decides to give me it? lol
lol dont know thats why I now own a REVOd cupra and its miles different lol.
Gave up with the DE-DPF game as I thought it was a little overrated......
Had a couple of rolling roads in many different gears and all were around 203-210bhp not any where near the 230-240 bhp and that was with full milltek and WILD map.
Maybe I just had a dodgy car but I wasnt too impressed most of the time.
