engine and gearbox are now in and all good.
battery has gone dead so will charge that up for the big start up.
quite nervous as ive changed and modified so many parts,
quick shift is in too L:)
turbo time
Took my spare turbo in with me today.
took it all apart and the only thing i could see wrong with it was a slightly bent compressor fin. has the same play as the new k03s in the car just now even although this one has done 100k miles!
no cracks in the housing either. so this is the turbo i will send away to be re-built.
WHAT COMPANY DO PEOPLE RECOMEND?
too many to choose from. cr turbos might be the best option.
orderd some parts from sere motors. david is a legend and brilliant costomer service.
thanks again
CRTurbos mate, I have just used them and have been brilliant.
sound like these guys will be the best,
i have been quoted 550 for a hybrid but ill be going BT at some point so theres not much point.
cheers for the advice guys, ill give cr turbos an email for a price on a rebuild
true... true...
any luck on finding 20mm rods?
Havent tried yet mate, It will be a while untill I will need them as the standard rods will do me for k04..
Have you tried IE to see if they have the rifled rods in stock? They are a little more expensive but supposedly better
yeah i have bud, but no luck....
need to look into valve stem seals and valve guides also. any experiences? done it on a couple of vts heads but these will be different surley
I have rebuilt heads before but again like you not on a 20v.. looking at other peoples threads cant see it being much different just 4 more inlet valves! Someone correct me if I am wrong??
Im sure a search will get you bundles of useful info mate.
got a price from crturbos, £295 up to £395 plus vat plus cariage. ( quite dear i thought )
ive emaild turbo center uk to see what price they do them for.
Wot shift , mine bent a rod then snapped it causing a big bill ££££ don't use it with out uprated rods , altho my ftlb might be higher than yours causing it to happen sooner
yeah that is some amount of torqure your pushing. seems like its more comon to go on the LCR's than anything else.
ive been looking for rods but ie still dont have any in stock!
