i wouldnt go orange as i dont think it will suit the mk4, white is safe and looks lovely, but there was never a white mk4 cupra made so its still different, why not get this kind of white?
one of jakes old cars
and this is nice too
Putting the LCR rear discs on would you say its worth it? Cant help but notice how small the ones are on the rear of mine :(
I actually would. All in I paid £160 for mine. They look better, the handbrake is 100 times better and it stops the nose diving so much under hard braking.
It's what seat should have provided with them
Yeah sort of thinking about doing them for my next mod. 1 more question :p when braking heavy in a straight line theres a bit of vibration coming through the steering wheel thinking about poly bushing the underside of the car you think they would eliminate this?
If you're getting vibration under braking it's most likely you have a problem. And it's more likely to be the front brakes tbh. I've got every poly bush available on mine (I think) and it's ok. I'm getting a little vibration just now but I think it's down to a badly balanced wheel.
If I was you, I'd try to find out what's causing the vibrations first. Swap wheels front to rear, and check for disc runout/warp would be my first things to try
You shouldn't be getting vibrations when braking. Is it the abs? Or is it because you have grooved discs maybe?
Bushes definitely won't improve an existing vibration. If anything they'll prob emphasise it
Been busy with 3m carbon wrap the last couple of days. A couple of quick iPhone pics
I also done the stereo surround plus new side lights and no plate lights. Need to get my camera out and get a few decent photos
The carbon is quite subtle from a distance and I'm not 100% on it yet. Think it might look better if my wheels go matte black
