Fluttering / Boost Related?
-=Rob=-
Beer or Car?
Dec 14, 2002
1,492
South West
Visit site
Rob, could you refitt you old filter box and try (I cant seem to find mine, think my ex girlfriend stole it:) shouldnt take long thou.
If I can find it Prebs I'll have a go, it's buried in my shed somewhere! Maybe next weekend now, other thing I was going to try was to re-fit the standard Bosch DV and see how that works... Something to cross off anyway!
Apr 15, 2009
2,189
Midlands
I get this on mine since fitting my k03s turbo
Normally its the usual tsssh from my 007p
But if i open it up and take it high up the rev range i get flutter noise with it
I ignored it as thought if it was a problem it would chatter/flutter all the time?
Prebs
662
Norway, Bergen
Dan, did it do it before you fitted an open filter? We are wondering if this noise is in fact normal...
I first noticed the fluttering sound when I was running the dynatwist enclosed air filter(green filter) and had problem with g/s readings from my maf witch was to low. I then removed the "bucket" so the filter was fully open, thats when I first heard this sound. I also got higher g/s readings but still to low so changed maf and it was sorted. Turns out the oil from the filter had started to make the maf read uncorrectly. Bought a AEM dryflow (dk2029) filter and had the flutter sound ever since!!!
Maybe we are worrying for something that´s close to normal???
Aug 27, 2010
893
yes since i took out the enclosed bit of the sound started!!
boost was better since the enclosed bit was taken off holds better etc
so will my turbo die soon then?:whistle:
-=Rob=-
Beer or Car?
Dec 14, 2002
1,492
South West
Visit site
Wont make any diffrence Im affraid, both me and Rob have tried this and loads of other stuff incl re.fitting N249/N112. Never got to the bottom of this Im afraid.
Thought I'd ressurect this thread, I still have this fluttering thing going on! The next thing I’m going to try is moving the DV to the coldside I think, but have notice a supersize DV on the Forge site - Has anyone every used a Forge supersize DV to fix this issue?
Aug 27, 2010
893
Rob what dv do u have
I now have 007p yellow spring no flutter on way it will have that now is that your bypass is wrong way round
-=Rob=-
Beer or Car?
Dec 14, 2002
1,492
South West
Visit site
Dan - I have 007p with yellow spring, it is been in standard position and reversed (currently reversed) - I have no by-passes in place, but all vac lines are 4mm internal diameter silicone pipes.
Aug 27, 2010
893
Hmmm werid one I plumb up something wrong the other day, and it flutter loads so thought that should be plumb in that way so change it back no flutter lol
Werid take it all apart and start again rob
Prebs
662
Norway, Bergen
I´ve gone down the Hybrid route, still fluttering same as with k03s. Forge 007 with yellow spring.
My hybrid map isnt working as it´s supposed to tho but still small fluttering.
Aug 27, 2010
893
I've got hybrid as well only get once in a blue moon now alot better map is over fueling so getting flames instead if flutter
-=Rob=-
Beer or Car?
Dec 14, 2002
1,492
South West
Visit site
Hey Prebs, still trying to sort this one! Remind me, is your DV on the hot or cold side?
Prebs
662
Norway, Bergen
Hot side, also freshly serviced with new seals, oil and yellow spring, still the same. Also pressure tested the DV, everythings normal.... except the fluttering:)
-=Rob=-
Beer or Car?
Dec 14, 2002
1,492
South West
Visit site
Hmmm, same here. So I'm going to get a coldside relocation kit and see what happens. Not been done yet! If that doesn't work, then I'll try a supersize dv. Then I give up!!
