turbos
Mo Arif
V.A.G Planet
May 5, 2010
2,510
Birmingham
you can use ANY turbo on ANY car if you know how........
If by T3/4 you mean a Hybrid Garret T3/4 then yes it has been done before but a lot of work is involved in it, new manifold, new downpipe, bigger injectors, bigger MAF, bigger FPR, custom remapping.....
Depending on your Leon, assuming it's a 'Cupra' ..... most people go for the Garret GT27 / GT28R series or Hybrid K03S or K04 .......
Your not looking at this T3/T4 claimed for a Cupra on eBay are you? :
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=400209693412&ssPageName=STRK:MEWAX:IT
That will fit, but a hell of a lot of work / custom fabrication is required to do so, also these import turbo's seem to be a hit and miss unless.... you buy everything but the turbo and manifold, buy a genuine Garret T3/T4 etc etc
skiddusmarkus
133
I think the T3 relates to the exhaust housing and the the T4 the compressor hence T34.Overkill unless you want to run big boost and far behind current Garret/Borg turbos in terms of response.
What's the spec of the gt27 turbos?Never seen them listed but assume its the usual 54mm exhaust wheel and between 60/70mm compressor?
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Yeah i think thats right....But cheap turbos like that and theres aways too big....
If he was going todo a Bt conversion on the cheap...then it would be IHI/Mitsi Setup as the turbos are cheap 2nd hand and easy to come buy...
the only expensive part is the Manifold like,JBS,tigart and JS..
oldskool
Please tell me more Danny
which IHI turbo, which manifold etc ?
Here he goes again,[B)] what happened to just running it like it is a the moment and enjoying it. Youre going to end up with a BT set up somehow , lol:)
Mo Arif
V.A.G Planet
May 5, 2010
2,510
Birmingham
hehe :whistle:
Was going to ask ya, those D.V's in your avatar?!! are they Forge 007p's ? if so did you get them sprayed?! they look awesome!
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Far point will argue about doing a BT on a budget but its possible...
On my Ibiza i ran New tigart manifold,Vf23 And revo stage 3 with 550cc injectors and made my old lines,tip,gear linkage bracket ect
from memory i did the conversion complete with £1200... Everything was brand new bar the turbo (which is a error in most peoples views) turbo cost me £120 and was in mint conditon...of scoobynet.
I had it running for 5 weeks before the water pump failed and i rebuilt it...Shame really the Rest is Old news..:(
What it looked like when i completed it..
Offt how i miss that creation of a weapon:(
oldskool
yeah theyre 007p ones, i have had them anodised ,so they will last ages. just refurbing them and punting them
oldskool
That looks an awesome car, what power was it running?
