A few of you know I'm trying to change my ECU to a wideband one, did the conversion yesterday although I've come up with a few errors, wondering if anyone can shed some light:
6 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17069 - ECM Power Relay Control Circuit (J271): Open Circuit
P0685 - 35-00 - -
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-00 - -
17931 - Crash Signal from Airbag Controller: Implausible Signal
P1523 - 35-00 - -
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
17523 - Oxygen (Lambda) Sensor Heating: B1 S1: Short to Ground
P1115 - 35-10 - - - Intermittent
The lambda fault was a fuse so I believe that's sorted.
My main concern is the throttle pedal doesn't do anything, the car runs OK, fairly lumpy though and odd missfires.
Any help appreciated.
Joe
Edit - ECU I'm using is AUM from Bora 1.8t 2002
ECU car came with AYP 2001
6 Faults Found:
P0685 - 35-00 - -
P1650 - 35-00 - -
P1523 - 35-00 - -
Joe
