Well folks had the car into the stealers for "warranty". Which was about as much use as a chocolate teapot! So in the end i got charged for the diagnostic as my car is not standard lol.
Here's the VAGCOM fault code result.
I would just like to add i am not taking the car in for them to do the job. But i am looking for any advice for where this sensor is located and how easy a job it is? As they were annoyingly very vague about it. Eeven after me repeating myself a few times.
Here we go:
1 Malfunction detected
0552 P1592 006
Altitude sensor signal/air pressure sensor
Implausible ratio
Intermittent
Measured values
0 mg/H
1012 mbar
1124 mbar
0 %
These are the parts that they say is needed
Quote " Checked for glowplug warning light on. Carried out guided fault finding. Found car to require wiring loom for sensor G31/G42, map sensor. Car also requires all earth points cleaned and engine ECU software update to rectify fault. (ECU HAS been modified)
£227inc VHC "
First of all i can't have an ecu update as then my car will try and regenerate when there is no dpf to regenerate with. I doubt that is a necessity. As all i have ever done with exhaust sensors is replace the part and delete the fault on the diagnostic.
As has been said before does anyone know of this fault? How hard is it to change the "wiring loom for sensor G31/G42"????
Cheers folks would really appreciate as much input as possible please.
Here we go:
0552 P1592 006
Implausible ratio
Intermittent
Measured values
0 mg/H
1012 mbar
1124 mbar
0 %
£227inc VHC "
