CluneZ
324
West Yorkshire
Updated 19/11/13
Engine and gearbox:
Seat sport FMIC with custom uprated 2.5" pipework
1.8 20vT
N249 bypassed
N112 bypassed
SAI removed and blanked off
Forge coldside relocation kit for DV
Beach Buggy Turbo 80mm oversize TIP
APR R1 DV
80mm jr08001 cone filter extended towards the wing
Custom made Aluminium heatshield
Polished inlet manifold
Hi flow cast manifold
3" decat turbo back exhaust made by Longlife
ECS magnetic sump plug
G60 Lightened and balanced flywheel
VR6 clutch
Peloquin limited slip differential
Badger 5 inlet gasket
550cc injectors
K300 Beach Buggy hybrid
80 mm MAF
'R'-Tech custom hybrid map
299bhp and 299ft/lb
Interior;
More lack of interior really, back stripped and sprayed satin black
Jvc headunit
Cupra interior :p
Vanilla magic tree
Exterior;
Gloss black roof
Gloss black powdercoated alloys
Hideaway plate
Badgeless grill
Purple dice dustcaps
rear lights tinted
Custom made big mouth grill
Handling mods:
Seat sport (AP Racing) 4-pots
KW V1 inox line coilovers
Whiteline rear anti roll bar
Superpro engine steady mount
Forge rear strut brace
Probs missed something but there she is :D
Hope you likes it
mate, whats the superpro engine steady mount? how much isit and how easy isit to fit? car is lovely btw.... although im sure ive told you that!
Foulkes- Ye you have mate cheers again though ;)
Bough it from awesome gti, can't remember how much i paid I got that and the rear anti roll bar at the same time and got em a bit cheaper, for what they cost it's one of the best value mods, around £40 I think anyway
I know the clue is in the name, but what exactly does it do and how east isit to fit?
Almost eliminates engine movement on acceleration and makes it easier to put the power down.
When you accelerate off the line does it clunk and do you spin lots? If so it basically stops that.
Will take 15 mins to fit and that's jackin the car up and gettin the old bush out, blow torch recommended and just burnt it out ;) then lots of lube and a heavy ba$tard to help squeeze it in. Unless you have a vice which would make it even simpler :)
Relocated my battery to behind the passengers seat today to free up some space in the bay to extend the intake in the long run
Surprisingly it wasn't too simple unfortunately
Sounds good... yeh it does spin quite easily if im giving it some beans... good mod?
Finally got a forge TIP and fitted that and a hard pipe to put the filter near the wing
Before;
After;
Will be making myself a heatshield for it either Monday or Tuesday. Just need to go find some ally sheet, bit of insulation and some gold reflective tape/wrap
nice car buddy,like the front with the plate to the side,you should do away with the filter exstension and fit a big filter in there ive still got my battery in place and my filter is probably twice the size of your halfords filter,i use to have the halfors filter then changed to a huge green cotton filter and supriseingly it made the halfords filter seem restrictive.
so i got a nice new big ass jetex cone, well big compared to my old halfords special and I also made my own heatshield [B)]
New cone:
heres the finished product :D
