hi is there a guide anywhere to lowering a cupra because i really wan to do it this weekend but im not sure how hard it is and how long it takes any help would be really appriciated thanks alto tom
No, just remove the front suspension and then use a spring compressor to remove the top cap off... rears are pretty simple, just remove old spring and put new one in place
To fit the springs, for the front you need in the to remove calipers and disc and let loose all the suspension. For the back you need to remove caliper but no the disc, and loose the suspension.
For the front is kinda slow to do it since you need to remove a lot, so it will take 40 mins each wheel, and for the back is like 20 mins each.
Be careful with your old coilovers, if they hit them you will need to replace them. The cylinders are kinda fragile. And a hard hit on the side could make them lose fluid.
It isn't that hard to do but as Spurt says if you really don't have a clue, it might be wise to get some help. When you do change your spring's, get your tracking checked afterwards. It may not be out but it is cheeper to have it checked and be sure, than to fit two front tyres.
