N75 knackered - symptoms?
auq
Avoiding Potholes!
Feb 11, 2010
652
Leicestershire
I think my N75 is playing up as lately, im loosing boost sometimes, car feels like its almost dumping all the boost and there's no power atall, very intermittent, i have to pull off quite carefully to avoid this from stationary.
Ive searched here and maybee think its swaying towards N75 valve?, ill get a vag-com scan done asap, dont think its hitting limp mode either
any advice would be great ;)
kaspa_dtz
84
can you keep this thread updated mate if you manage to get hold of one, my syptoms are very similar and i havent touched the N75 yet....
auq
Avoiding Potholes!
Feb 11, 2010
652
Leicestershire
Thanks to (seatcupramad23) for this very handy information! ;)
the ogignal auq engines had c valves but were prone to fail and seat made uprated valves later on after 2004 i' told called f valve then lat year seat again replaced the f valve with the newest e valve ,
the j valve is aggressive and cause higher initial spikes boost comes slightly earlier but tails off earlier also, if your car was mapped on a c, f , valve only replace it c, f or e valve it will cuase trouble if you use j valve without visiting tuners again
waynepixel
Newbie
Aug 14, 2006
135
Kent- Medway
I had this problem last year and it turned out to be the N75 Valve, and get this, when I got a VAG Com scan it did not pick up the fault because it was intermittent so it was the last thing I changed. An indication it is the N75 is a fluttering noise from the Turbo on boast.
leon_lee
62
northampton
mines got similar symptoms, boost spiking way higher than normal intermitantly and then dumps all boost, this can be felt mostly when flooring from low revs in 2nd or 3rd gear, the boost builds and then goes way past normal, then you hear it dump with foot flat to the floor and then boosts again. I've checked GSF but they don't seem to list the N75 valve so i might have to give the stealers a call tomorrow for a price. I might order a clutch switch as well as i think mine might be knackered too but will try the N75 first.
stig1
when you say you had the boost fluttering do you mean like mine is its up and down between 1.2 and 1.6 bar it like bounces when you floor it and the boost builds up
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
care to share?
Posted above Bill
