Yeah in stock and even with 18's I'd say stick with 15mm if your not putting any on the front.
Damian @ DPM Performance
Will be doing front to!
Sick of thinking about this now il worry about the 19s when I have to!
What's the price on a set of 20mm fronts and 40mm rears delivered bud.
Gaz
Hi bud
Last line of your last post did you mean 20mm rear and 10mm front?
Just checking.
All I've got planned to do is fit the eibach sportslines and get 4 wheel aligned.
Run the freshly powder coated Cupra wheels for a while and then maybe buy some bbs ch 19 inch wheels and run with 235/35 r19
Obviously I'd try and get them in the nearest offset to match the standard wheels but they may be 8x19..........
Would the spacers be too wide then in this case!!
Yep, I edited my original post.. I would say if your going with 19x8 rims then play it safe and stick with 10mm at the back and maximum of 5 at front, I will fitting BBS CK's 18x8 within end of next week and will report back how things are going.
Are you wanting 10mm (20mm per axle) front and 20mm (40mm per axle) rear?
20mm total front-10mm each side
40mm total rear-20mm each side
If you agree?
Will be lowered on eibach sports lines at the end of this month and also 4 wheel allignment done at same time!
Will worry about the bigger wheels when I get them!
Bringing this up again! Any pics of these cupras with spacers...
Thinking about 10 front and 15 rears.
10mm front
20mm rear
By gazhill81 at 2011-10-02
Exactly the same width and offset I'm looking at next but 19 inch!
Not sure it'd help if you took a pic of the side of the car close up so I could see what you have to play with
