Only if you hit limp mode as far as I know, usually the ecu shuts off the turbo if the boost is outwith spec then you'll get a code for either under or over boost.
Check for a leak in the exhaust around the turbo, you might see some black soot marks and also the flexi for the egr valve, once again check for any sooty marks.
