Tools/Parts needed :
Torx screwdriver (T30)
Large Flat head screwdriver
Small Flat head screwdriver
Pair of latex gloves
TMC Tuning Box Kit
Car used :
2011 MK2 Skoda Fabia vRS 1.4TSi
Time needed :
About 20 minutes but allow a bit more
Difficulty :
3/5 - A couple of plugs are fiddly
**MAKE SURE THE ENGINE IS COLD WHEN INSTALLING OTHERWISE YOU COULD END UP GETTING BURNT**
You'll have this to start with :
Engine bay should look like this :
First thing you will need to do is remove the engine cover, this is done by gently but firmly lifting the bottom left and right corner then then pulling the cover towards you :
The three plugs that need to change :
Turbo boost pressure sensor plug
Camshaft sensor plug
Manifold air pressure sensor plug
Let's start with the turbo boost pressure sensor plug, you will need to remove the turbo air intake pipe by removing the below Torx screws (some already removed but locations shown) :
TMC Tuning Box Kit
Car used :
Time needed :
Difficulty :
