Marshall
3,256
Bonnie Scotland
After looking at some videos on you tube I found a mk2 Leon cupra R which showed the vehicle speed readout in large numbers on the mfd not just the little readout we get at the bottom.
Wondered if anyone knows how to do this?
Sent from my HTC Desire using Tapatalk
iirc; It’s required by law in the UK to display both MPH / KPH at the same time, don’t think it’s the same for Europe. Might be able to change it through VAG COM :shrug: but change it back before an MOT.
cant you change it through the mfd settings?
ive seen it done this way on an Audi A3
You could change it on my old MK2 TT, but not on this MFD for some reason. The lay out it slightly different, showing KHP between two small lines at the bottom of the display.
On my phone at the min but if you go on you tube and type in Leon cupra r facelift its the first video.
It's KHP though. It's displayed as my TT use to, however If you look closely the outside temp is displayed where the UK version of the KPH is displayed.
Our cars display the outside temp above the two horizontal lines.
Must be programmed different or an option through VAG com, as no option through the MFD.
The european R does not have gloss back seats or the rear diffuser.
Was just curious if I had missed how to do it.
Thanks for your info.
You wouldn't buy an R if it didn't have the darth vader seats and the dual centre exhaust setup would you?
Not at all bud :) i also had a good look for it, and could not find it.
iirc the price is quite high for the R in europe.
You can't set this up on the MFD. Not looked to see how its done in VAGCOM.
may be a red herring but also maybe worth a go - rest of the world???
www.golf gti forum .co.uk/index.php?topic=186423.0
(ditch spaces)
D
Cracked it! :D
This is such an easy re-code to do, literally took me 2 minutes once I found the right menu.
Made a step by step guide if anyone is interested in doing it theirselves:
(Apologies for the crappy phone pics)
Step 1: Connect up to VCDS/VAGCOM in the usual manner, then select Instruments under the Select Control Module menu.
Step 2: Select the Coding sub-menu
Step 3: Select Long Coding Helper
Step 4: Select Byte 0 Bit 4.7 drop-down menu then select 10 Country: Rest of World (RoW)
Step 5: Exit Long coding helper then hit "Do it"
That's all you have to do on VCDS/VAGCOM but now you will have to change your MFD Settings, Units menu to the correct UK format from US format (imperial to metric).
Step 6: Un-tick the Alt.speed dis to activate the "Alternative Speed Display"
Step 7: Final stage - Change your units for Consumption to MPG and Temp to ˚C.
Job Done, hope this helps!
Greg.
nice one!...
What hardware/software would i need to do this, and also how much would it cost???
nice one!...
It can cost anywhere between £50 second hand off ebay up to £200 odd for the genuine Ross-Tech cable & programme.
You should put a post in the VAGCOM requests section on the forum and see if anyone in your area can sort you out!
If your in the West Midlands I be more than happy to help you out!
Cracked it! :D
Greg.
So after this you have a MPH display upfront? pics :p
Also noticed your car is Facelift bet this dont work on Pre-FL
Cheers for the offer, but im in Barnsley, South Yorkshire....
Ill have a look in the other forum...thanks for working out how to do this and for the VAGCOM advice...
