but change it back before an MOT.iirc; It’s required by law in the UK to display both MPH / KPH at the same time, don’t think it’s the same for Europe. Might be able to change it through VAG COMbut change it back before an MOT.
Was just curious if I had missed how to do it.
Thanks for your info.
You wouldn't buy an R if it didn't have the darth vader seats and the dual centre exhaust setup would you?
Sent from my HTC Desire using Tapatalk
You can't set this up on the MFD. Not looked to see how its done in VAGCOM.
may be a red herring but also maybe worth a go - rest of the world???
www.golf gti forum .co.uk/index.php?topic=186423.0
(ditch spaces)
D
I'm off out to the car to give it a go... watch this space![]()
nice one!...
What hardware/software would i need to do this, and also how much would it cost???
Cracked it!
This is such an easy re-code to do, literally took me 2 minutes once I found the right menu.
Made a step by step guide if anyone is interested in doing it theirselves:
(Apologies for the crappy phone pics)
Step 1: Connect up to VCDS/VAGCOM in the usual manner, then select Instruments under the Select Control Module menu.
Step 2: Select the Coding sub-menu
Step 3: Select Long Coding Helper
Step 4: Select Byte 0 Bit 4.7 drop-down menu then select 10 Country: Rest of World (RoW)
Step 5: Exit Long coding helper then hit "Do it"
That's all you have to do on VCDS/VAGCOM but now you will have to change your MFD Settings, Units menu to the correct UK format from US format (imperial to metric).
Step 6: Un-tick the Alt.speed dis to activate the "Alternative Speed Display"
Step 7: Final stage - Change your units for Consumption to MPG and Temp to ˚C.
Job Done, hope this helps!
Greg.
