Cupra_Mat
309
Sutton Coldfield / Lichfield
Trying to clarify the differences in fuel pumps after lots of reading :confused:
Cut a long story short think i have a tired failing fuel pump and looking to uprade whilst in the process of replacing.
Is there any difference between the cupra and cupra r fuel pump? or would i need one out an s3?
Would i see any difference by just upgrading the fuel pump performace wise?
Thanks!
1st of all replace the petrol filter and see if it helps :D Could be clogged...
For engine codes AUQ AMK BAM you need the S3 fuel pump, part number: 8L0919051H
Stock pump is rated to 5 bar iirc, so 3bar fpr plus what boost you are running, a 4 bar pump won't cut the mustard.
hmm, so the stock cupra pump is good for 5 bar? & the s3 only 4 bar?
Going to try a new fuel filter 1st for the cost of a filter its worth a try....
I do have very leaky injectors atm so whether thats causing a mist under boost and upsetting the fueling?? & had a couple of failed starts due to pump not kicking in.
Had no problems with the pump starting since tho, very weird :confused:
I got some seals from bill so ill try a new fuel filter, seals, relay this weekend see if it seems any better ;)
