Dead leon 1.8t help?!
leon_cupra_666
thats the strange one Vag-com wont communicate with the engine but can with ABS etc.....when you put the key in the ignition all the lights come on except the EML one its like a relay has gone etc but replaced the 409 is there one for the ecu?!
leon_cupra_666
yep all straight of a 2001 cupra same car so plug and play same fault as the original ecu.....any ideas guys need your help?
leon_cupra_666
anyone out there recommend a god VAG specialist in the Bedford Milton Keynes area?
not sure how to check the power to the ECU? does anyone know if there is a relay for the ecu?
davidhunter
122
have you tried putting the car into transport mode via VAGCOM? really not an expert in these things but put it into that then out of it. Never tried it myself but I would have thought that would reset ECU or have you disconnected the battery for 30 minutes to reset? What about disconnecting the O2 sensor again incase its leaving some sort of open circuit that would stop you getting into the EMU possibly.
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
It's mk4 golf basically and this is the mk4 golf board
The one with 100 on it is the only relay i can see it being, if any
leon_cupra_666
its worth a go am literally pulling my hair out trying to think of what else it can be....would faulty MAF or Crank sensor stop it from starting?
the TCS light is on flashes twice but when i scan it with Vag-Com it says faulty steering wheel position sensor had that since day one used to come on and go off from time to time?!
leon_cupra_666
no says mechanical failure but as its been like that for months usually means your steering wheel is slightly off centre dues to tracking etc......anyone know anything about relay 428 under the bonnet ECM relay?
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Have you got that relay?
ECM Engine Control Management? try and swap it with a known working one, or maybe you can short the longer prongs like the fuel relay, not sure on that.
leon_cupra_666
just bought one off eBay...feel like im p1ssing in the wind a bit.....appreciate everyone's help though!! any other suggestions please let me know?
leon_cupra_666
No 469 but mine is an AUQ and it has 2 relays under the bonnet near the maf hidden in a black plastic box.....one 428 and 100....not seen a 469 anywhere yet!!
cupra_r_ick
1,076
let me get this right, its cranking but not firing ?
you got fuel ?
got spark ?
got nothing ?
faulty crank PS sensor would stop it starting. it wouldnt, as would cam position sensor.
maf wouldnt stop it starting
grahams81
1,165
County Durham
Don't know if its worth mentioning but there are fuses also in the black box on top of the battery, loads of red wires go into the box.
They are open fuses with varying sizes, they look like dog bones of thin metal connecting two wires to each other.
Do you have a multimeter ? Because it sounds like your going to need one.
Personally i would start by checking your voltages on the fuse board.
Blade fuses normally have a bit of exposed metal on the head which you can use to test voltage or continuity.
You shouldn't continue buying parts and swapping them with guess work, either contact an electrician or buy a multimeter and start checking voltages at varies parts of the car.
Hope you get there in the end.
