Don;t pay your self. Just phone Seat UK. They told me to book it in there and then and I had it done the next day!
I think I may well have this issue. My heart sank when I saw a 27 page thread on this problem! My car cut out completely on the way home last night but started again. Luckily there were no other cars around and I was on a straight road.
I am letting the dealer come and get it and repair it and I will pay them whatever they ask. I will then recoup the money from Seat UK (if it is this issue). If it is this issue I am confident I will get all my money back seeing other reports on this thread (made my day!)
But the cutting out totally worries me as you lose power steering! That could be very dangerous even if it does only happen once every 3 years......thinking of changing to a common rail or older different engine....mainly because of my daughter..
Awesome. The garage just called. As I expected, it is the injector and all will be replaced FOC.
I didn't even have to ask. Top marks.
Lads can you give me a bit of advice please.
Had a phone call this morning from the dealer alerting me to this injector recall. Its booked in for the check.
Mine is mapped should i get map removed ? And if i do will they still be able to tell the ecu has been tampered with ?
Mine is a 2008 FR and i have had the odd total cut out from the car in the last 6 months but it always re started. After reading this thread im very worried as i do a lot of motorway mileage with young children in the back and now i just have no confidence in this car at all.
Any tips on forcing Seat to exchange the injectors regardless of having the faulty part number or not ?
Just really need to feel safe in the thing again.
thanks
Mine was stage 2. Just told them no ecu updates. Dealer was brand new![]()
Could they tell though if they looked, not bothered about them over writing it but can not get the standard map back on in time. They told me it just a check so would they look at the map ? If i have the bad injectors they have to order the parts and then take it back is what they said.
Hi everyone. I have Seat Leon FR170 2007 and I decided to call SEAT Customer Service myself to find out if my car needed the injectors replacing.
After I gave them my REG they said that yes it is one of the cars affected and that I shouldn't worry as it's not a safety issue as such, but just a courtesy service they are changing them as many have been failing. They said when they fail your power steering and brakes should all still work fine but the car will lose power? (different to what some people on here have said..)
Anyway I was told to ring my local SEAT dealership to get it booked in for the Injectors to be replaced. They said this would all be free of charge (including a courtesy car for the day).
So I have booked it in for 16th Jan. The dealership said they were aware of the issue and they will do all the work no problems.
So when I have had it done I will write another update on here to say how the car feels after.
I should add that I haven't actually had any issues with the car at all, but I thought I would see if they need changing anyway after reading this thread!
Compo1 - If you have the bad injectors which you probably will have then I don't see why you have to take your car in to be checked? It can be done over the phone using your reg or vin. Mine was done over the phone with the dealer. I would just ring them up and ask them to check, it will save you going in and then them telling you to come back again because they'll have to order the parts in.
